lelliott731
[H]ard DCOTM April 2017
- Mar 15, 2002
Do you guys think it's a better deal to use WCG for my CPU threads instead of F@H? Doesn't seem like they are doing a whole lot with F@H CPU these days, mainly using GPU's?
I run multiple rigs that do both F@H and WCG.
Just make sure you dedicate at least one core per GPU for F@H on rigs that are sharing CPU resources. So basically if you have a quad core CPU and 2 GPUS. Set WCG to run 2 tasks on the CPU only. F@H will use the other 2 cores for it's GPU computing.
My daily rig has 2x 970 GPUs and a quad core processor. I have 2 cores dedicated to WCG. F@H runs on the GPUs and my CPU usage runs at 100%. The only time I notice any kind of slow down is when I try to play a graphically intensive game. Pausing F@H while I play solves the issue completely.
