Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Sometimes there is a small delay from when you change your preferences on the WCG site and when their servers actually get the "update". Also, if you change the "My Projects" selection it will override the all of the individual device profiles you may have set up. (home, school, work, default)
when you change your settings make sure you go into boinc and update the project each time you change a setting. otherwise it will wait until the next time its set to update which is every 3 hours by default thus ignoring any setting changes done between the last update and what settings are set at the time of the default update.
