WCG opteron 2419 vs xeon e5440
BLACK@BLUE
Hi guys, I dont post much but my little farm of old pc's has been going for a year this 24th doing WCG.
I want to do a little upgrade to my farm, which is my main pc and then 3 c2d 1.8ghz 2mb ram. The 3 c2d are what I will be replacing with either the opteron 2419 or the xeon e5440. I tried to search on the net and didn't find anything on how good either were at WCG and thats why i'm here asking you guys, if you had no other choice but one of these two cpu's which would you pick and why if you don't mind telling me.
I hope for another year running WCG and being part of this team.
Thx, BLACK@BLUE aka CAP_USAF
The Opteron would build badges faster and uses Half the electricity. The Xeon would score better points per work unit, but I don't know if the Opterons extra 2 cores would compensate or not. I don't know about the Heat comparison between the two. I would also take a look at future upgrades and GPU support on the boards. Do you have any specs in that arena?
Since the Xeon is a higher clock speed, it would run hotter even though AMD's usually run hotter then Intel. This is a guess and someone else may be able to give better incite. So, I can't tell you how much difference or if there is any. If you plan on using GPU's which is where the big points are currently, it really depends on the GPU. If you have a high end card and use an app_info/app_config file to run multiple work units at a time on the card, then you would need the faster clock speed from the Xeon to fully feed it efficiently. Also, if you are one of the few are are truly looking into the Xeon Phi cards, you would need the Xeon to feed it as well. I have a feeling though that this will not happen before this system gets replaced. Especially since it is not confirmed that those expansions will even work yet at WCG.
I also have no experience over clocking either of those chips, so maybe someone else could chime in if that is something you are also considering when making the choice.
Hi Black@Blue - Good to hear from you. Like Gilthanis said the 6 cores in the Operon would be better for chasing badges if your interested in that. While I've not had any experience with the Opterons, I would agree that the Xeon would likely yield more overall points because of the clock speed.
Any reason why you chose those two CPU's? Local seller, access to compatible motherboard? Might consider overclocking potential of the two chips as well (depends on the MB of course).
Good luck with your decision. Let us know if we can help. Thanks for contributing to the WCG!
Black@Blue, I also go by the handle Coleslaw at all the BOINC projects if I run into you in the forums. Feel free to say hi. We are glad to assist with any other questions you have. We also do a lot of BOINC discussion in the DC Vault 2 thread found here: http://hardforum.com/showthread.php?t=1620596 We would be glad to have you join us there.
Hi guys ty for response.
Well the reason i'm asking about the opteron/xeon difference is I have gotten all my parts for 2 opteron dual 6core setups and was planning on going naked, my son who is about 2 1/2 plus other concerns have made me have a change of heart on going naked. The xeon setups come complete in a 1u server cases with dual 4cores. Both setups have same ram amount/speed.
The e5440 xeon's are by far the fastest xeon's in my budget range but I didn't wanna take a chance on them if they where not close to what I would get from the opteron's. So really it just comes down to hearing I wont lose much if any by going with the Xeon's.
I read the threads here once a week and of course the dc thread, i'm a set it and go type person so WCG works well for me.
I'm happy to be here doing what I can for the team and more so for trying to make the planet and our lives on it a little better i hope. Hats off to all you wonderful ppl.
Glad to have you WCG crunching with us black@blue!!!
Sorry I can't be any help with the processor choice. I'm running several dual/quad desktop machines. Mix of AMD and Intel. No server stuff for me.
I prefer cores for badge hunting and milestone goals. I'd go with the Opteron due to the lower power.
I would have to disagree with AgrFan on this one. The badges are tremendously easy to acquire when you have a small farm and thus loses a great deal of bragging rights these days. WCG is terrible at designing recognition with future expansion in mind. The Xeons will get you there quick enough. However, the Xeons will get you to point and returned results accomplishments even faster. Once badges are obtained, all you have is yet more run time that shows up in your own stats page. It is a huge complaint that has gone unheeded for several years.There is actually a forum post about a big contributor Astrolabe. that is leaving WCG behind because of reasons like this. However, with the Xeons you will get more results done which is the morale choice and will further our cause at the DC Vault more then the Opterons will. If you are trying to cut electricity costs or the draw on your home wiring, then by all means go with the Opterons. Since you are asking between the two, then you probably already have the finances to run them. The only other rationale choice for Opterons is if you were going GPU's and your power supply couldn't handle the extra power draw.
I decided on the Xeon's.
From the replys they will fit what I want to do in WCG just fine.
Thank you for the help.
I understand the argument for optimizing hardware for maximum points. But many people crunch with what they have and enjoy the milestones as they come. I don't want to be constantly upgrading hardware for point production reasons. I don't have the time or finances. I stopped running FAH for this main reason. I could no longer keep up the pace without constant hardware upgrades.
I crunch for the science as much as for the milestones. I would hope maximizing points is not the main reasons why we participate on WCG. All team contributions are important - big and small. I've been doing this 5 years now. I have Sapphire in all active projects. I just reached the 50 million WCG points milestone. It wasn't easy which makes it all the more gratifying.
... All team contributions are important - big and small. ...
Couldnt agree more AgrFan. :) Both points and run-time are just an attempt at quantifying "work done for science". The important thing is the contribution, and having fun while contributing! Some people, have more fun chasing badges, and some have more fun maximizing points. Either way research wins!
Black@Blue - Glad that you made your decision. Thanks for adding some more muscle to the cause. Crunch on!
can understand where you both are coming from,
Distributed computing is a personal decision about what projects you want to participate in, what hardware you can afford or deem resonable to use, going it alone or being part of a team.
How long of a run you make in distributed computing can be effected by several things and for most ppl good feelings well help keep you around and negative feelings can drive you away.
I'm lucky to be on a good team with ppl who invest thier time and energy into the forums. I made a quick buy of some item's that were a great deal but as time went on I realized not the best fit for my home situation, I found another deal that seemed a good fit in everyway except I had no idea if performance wise it was what I was looking for, with the help here I felt good about making the purchase.
These new units will be about 3 or 4 times faster than what I bought last year for the same price. I don't do DC to get badges or even climb some list, I have my reasons like all of you for doing it, I want to be able to do the most I can within my budget and that is what drives me to look for deals that would be an improvement to what i'm already doing as a byproduct it will be a little more help to the team which also makes me happy.
I'm glad were all here together working on DC like pieces to a puzzle when put together making a beautiful picture.
I would personally go with a high clocked sandy/ivy cpu, or perhaps a i7 900 series, a 6-core one if you can afford it. A single 6-core i7 970 @ 4.2 Ghz would be faster than either of the two setups you are considering.
No doubt, i'm guessing there are 50 to 100 combo's I could put together that would be faster than what I'm getting.
I'm cool with that though, I been running a year staight without taking an hour off in that time, 3 of the 4 comps are running just a single c2d at 1.8ghz 1.5gb ram, the upgrade will be 2 blades each with 2x4 core 2.83ghz 8gb ram all for 250.00 which was my whole budget.
I was happy for a year to be able to do what I could do and i'm actually pretty stoked with this upgrade for this year, with my budget and what you got listed i'm thinking it will be possible maybe in 2017.
Ok thought i'd update this a bit.
Decided while waiting on the xeons to put the opteron setups together, so I started one up and my wife let me know right away that wasn't going to happen in any room in the house : ( Is it just me or can women not handle noise as well as men?
Ok now for my big noob server mistake, I bought 2 blades thinking they were just like the other 1u's I looked at and had some sort of psu.
So here I sat looking at either needing 4 quiet opteron heatsinks with fans or 2 case and motherboard for blade parts.
I have 3 mATX cases that I love and have had for years sitting empty, I thought if I could find a mATX motherboard for either the xeons or the opterons then that was way I was going to go, didn't firgure there was much hope till I found this --> Super Micro X7DVL-L.
I hope to have this up and running next week and get the wife's thumbs up. i was gonna take some pic's in case anyone wants to see my little beauty : )
I learned some good lessons, even though ive put many pc's together I really nneded ask more questions before I bought server stuff.
Yeah...blades have a lot more fans inside and can get pretty loud at times. If you had the option of running them naked, it wouldn't be so bad. Water cooling would also up your investment a good deal.
Sounds like you got EE chips?
Mine have been running solid. Really happy with them. I still got to get the xeon's up and running, got everything but a psu, then i'll be able to see whats worth keeping, been looking at cases to get no matter which way i go, more kid proof than naked.
I know i'm no huge producer but for me after running for a year at around 70,000 a month it looks like i'll get 4x that this month, thats pretty cool.
04-13 221,575
03-13 90,329
02-13 70,070
01-13 76,009
12-12 63,034
11-12 66,805
10-12 56,706
09-12 387,136
Totals 1,031,664
no, ordinary 2419 chips, the ones floating around ebay for $10-20.
http://www.cpu-world.com/CPUs/K10/AMD-Six-Core Opteron 2419 - OS2419WJS6DGN.html
EEs are about the same
http://www.cpu-world.com/CPUs/K10/AMD-Six-Core Opteron 2419 EE - OS2419NBS6DGN.html
Phenommsrtweaker and undervolted like crazy :)
Statistics Date Total Run Time
(y:d:h:m:s) Points Generated Results Returned
04/23/2013 0:009:01:07:31 22,699 30
04/22/2013 0:013:13:04:59 34,029 44
04/21/2013 0:013:06:30:16 33,891 47
04/20/2013 0:009:04:42:51 23,137 30
04/19/2013 0:011:03:27:34 27,703 36
04/18/2013 0:009:02:09:30 23,543 29
04/17/2013 0:008:02:55:36 21,094 22
04/16/2013 0:008:03:09:24 20,486 20
04/15/2013 0:005:17:02:16 14,348 20
04/14/2013 0:014:22:21:26 38,404 60
04/13/2013 0:009:19:06:46 24,976 39
04/12/2013 0:011:10:21:38 28,835 45
04/11/2013 0:011:16:21:57 28,878 45
04/10/2013 0:012:16:59:43 31,700 47
04/09/2013 0:012:10:22:07 32,486 46
04/08/2013 0:013:09:15:28 35,115 51
04/07/2013 0:010:09:06:40 27,332 40
04/06/2013 0:011:10:50:46 29,874 45
04/05/2013 0:004:21:01:58 11,718 19
edit: http://www.ebay.com/itm/2x-AMD-Opte...Six-/111056961466?pt=CPUs&hash=item19db82bfba <- these
edit x2: the best part about these cpus while undervolted? :D
https://www.dropbox.com/s/24e5ktfu7gomnnc/Untitled.jpg observe coretemp readings under full load (it has 1x exhaust 12cm fan, 3x8cm cpus/chipset - all running at ~800rpm).
2419 EE 40/60
2419 75/115
I don't have alot of experience chaging settings, also energy savings for me is a must since i'm on a very small budget, the EE's could be the difference of being able to set up another like system.
True, but the change to be done in windows (using phenommsrtweaker) is trivial - thus basically getting EE for a lot less :) I built two of these systems and the first CPUs i was able to reduce from 1,275v to 0,985v. I dont think EEs are worth the money - if you get a really good deal then maybe...
IIRC the system used ~210-230w at stock/full load, so about 100w off with couple minutes worth of work.
https://www.dropbox.com/s/b6e4kyfmdt97svm/tweaker.png
Mine is running headless with Seasonic S12 II Bronze 430w PSU / 64GB Crucial M4.
