WCG hung up?
BLACK@BLUE
Hi I did some microsoft updates this morning and now I cant seem to get this thing going again. I've restarted several times, I uninstalled WCG and still this after reinstall. I have no idea what to do next so I'm asking you experts.
P.S. Also I have 3 other comps running with no problem.
6/27/2012 9:22:03 AM||Starting BOINC client version 6.10.58 for windows_intelx86
6/27/2012 9:22:03 AM||log flags: file_xfer, sched_ops, task
6/27/2012 9:22:03 AM||Libraries: libcurl/7.19.7 OpenSSL/0.9.8l zlib/1.2.3
6/27/2012 9:22:03 AM||Data directory: C:\Documents and Settings\All Users\Application Data\BOINC
6/27/2012 9:22:03 AM||Running under account
6/27/2012 9:22:03 AM||Processor: 4 AuthenticAMD AMD Phenom(tm) II X4 965 Processor [Family 16 Model 4 Stepping 3]
6/27/2012 9:22:03 AM||Processor: 512.00 KB cache
6/27/2012 9:22:03 AM||Processor features: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 htt pni cx16 syscall nx lm svm sse4a osvw ibs skinit wdt page1gb rdtscp 3dnowext 3dnow
6/27/2012 9:22:03 AM||OS: Microsoft Windows XP: Professional x86 Edition, Service Pack 3, (05.01.2600.00)
6/27/2012 9:22:03 AM||Memory: 3.24 GB physical, 5.08 GB virtual
6/27/2012 9:22:03 AM||Disk: 69.23 GB total, 7.67 GB free
6/27/2012 9:22:03 AM||Local time is UTC -5 hours
6/27/2012 9:22:03 AM||NVIDIA GPU 0: GeForce GTS 450 (driver version 28558, CUDA version 4010, compute capability 2.1, 1024MB, 421 GFLOPS peak)
6/27/2012 9:22:03 AM|World Community Grid|URL http://www.worldcommunitygrid.org/; Computer ID 1911797; resource share 100
6/27/2012 9:22:03 AM|World Community Grid|General prefs: from World Community Grid (last modified 31-Dec-1969 18:00:01)
6/27/2012 9:22:03 AM|World Community Grid|Host location: none
6/27/2012 9:22:03 AM|World Community Grid|General prefs: using your defaults
6/27/2012 9:22:03 AM||Preferences:
6/27/2012 9:22:03 AM|| max memory usage when active: 1657.46MB
6/27/2012 9:22:03 AM|| max memory usage when idle: 2486.20MB
6/27/2012 9:22:03 AM|| max disk usage: 7.40GB
6/27/2012 9:22:03 AM|| don't use GPU while active
6/27/2012 9:22:03 AM|| suspend work if non-BOINC CPU load exceeds 50 %
6/27/2012 9:22:03 AM|| (to change preferences, visit the web site of an attached project, or select Preferences in the Manager)
6/27/2012 9:22:03 AM||Not using a proxy
6/27/2012 9:22:03 AM||Suspending computation - initial delay
Im sure you have already tried this but have you tried the 'Update' command in the Projects tab? Are there any projects currently in your queue or are you out of work and now its just not getting new work?
Edit: It looks like the WCG is down. Now that I look at my other machine I have a whole queue of CFSW units waiting to upload and no new work being downloaded. There website is also down: http://www.worldcommunitygrid.org/
Nothing you can do but wait it out or load up some work from another BOINC project. :)
Funny thing is this is my amd machine, my 3 intel machines are working just fine, I dont know?
check if there is a newer version of boinc not on WCG's site, um you can also try doing a benchmark run and see if that works..
Well thanks guys for the idea's.
I went into the "Advanced tab" and did the cpu bench mark and it came back fine, so it got me thinking to try the "Do network communication" and sure enough it started up again on all 4 cores.
I guess I learned something new, just glad to be running again : )
