EternityZX9
- Sep 15, 2004
In the last 72 hours I have just learned the basics of how water cooling works and the parts needed to build a system. Now I am toying around with a setup, but I want the [H] Gods opinions on what would be best. Here is the setup I'm planing to use: (keep in mind I don't want to go anything bigger than using 2 x 120mm Fans on a radiator/heatercore)
- AquaXtreme 12V Pump OR Swiftech MCP600 Pump
- Airplex Evo 240 OR 77 Bonneville Heatercore (Both using TT A1280 120mm Fans + 1" Shroud)
- DangerDen High Density Reservoir
- DangerDen 6800 Water Block
- Cuplex Evo 1.1 CPU Water Block
- Twinplex for NB Chipset Water Block
- Tygon Tubing + CoolSleeve OR Primoflex UV Blue Tubing
- Zerex Coolant + Swiftech HydrX Additive
Alright, now for the questions:
1. As for tubing what size is best: 1/2" or 3/8", ID and OD, for cooling, I want the best performance. However, I don't want the Fans on the radiator/heatercore that loud!
2. Can I get the same barbs sizes on all of this equipment, so that I can have the same tubing throughout the entire setup?
3. I'm really confussed with what tubing size would be best for this setup and what coresponding pump/radiator would best as well.
4. Does water cooling the NB Chipset really make any difference? I have seen a lot of water cooling setups on this forum and a lot of people just do the GPU and CPU.
5. Would this system work with a single loop, should I go double? Would I need another pump?
6. What are the best clamps to use, where can I find them? I searched the forums, this part is still confusing to me.
7. In your opinions, should I get a different CPU / NB Chipset water block? If so, what?
8. Would I need a second power supply to power up this system?
Btw for a case I plan to use the Coolermaster CM Stacker and place the radiator/heatercore in the same position that is in the "Coolermaster Worklog" if that matters any. Coolermaster Work Log
