jhinck1414
- Oct 4, 2008
I am preparing to purchase a custom loop to WC my 2600k.
I am curious if i would be able to put a rad on the mesh side panel? I know this case isn't the best and I have seen plenty of poeple put a 2x120 up above the mobo.
Looks like it would fit either Phobya XTREME Quad 480 Radiator or almost any 120mm Duals out there ie XSPC RX240 Dual 120mm Radiator.
will the mesh support a radiator of any size? I feel that it would be a great place to put one without disrupting the rest of the flow of the case.
thanks
thanks
