WC Question.
pblou24
This is going to be a bet more than i wanted to spend but i'm also looking ahead as in adding GPU blocks for 7800GTs in SLI. Will this haldel that when the time comes.
Danger Den TDX Athlon 64 WaterBlock OR Swiftech STORM Extreme Performance 1/2" ID Universal Water-block
Swiftech MCR-220 Quiet Power series Radiator-Black
Swiftech MCB-120™ Radbox kit - Black
Typhoon - Dual Bay Reservoir - UV Blue + Large Reservoir Cap
Danger Den D5 12V Water Pump
ClearFlex 60- 1/2in. ID by 3/4in. OD-10FT
Barbed Y Fitting- 1/2
Barbed T Fitting- 1/2
Nylon White Hose Clamp- 1/2
PrimoChill ICE - UV Blue \
Buying it all From www.voyeurmods.com
If you get the TDX get the TDX + D5 combo from Dangerden, it will save you like 30$
But will most likely pay it back in shiping. Money wise its not that bad i can live with the bill just want to know if this will keep up with my upgrade needs.
yea it will handle it just fine.
A few things though, why do you have a plastic y listed? You shouldn't need a "y" fitting anywhere. You also dont need the T fitting either. Since you have the resevoir you just need the tubing and the blocks, unless you plan on making a drain line.
Also, dont get those plastic snap clamps. Go to your local hardware, or auto parts store and get the worm clamps that you screw tight.
yeah i plan on bleeding twice a year for cleaning and why not the plastic calmps? do they break easy or not last?
the plastic clamps dont hold up for a damn.
i had ONE around the inlet of my eheim and the thing shattered like glass when i tried to remove it. other than that ONE i use worm clamps. you cant pay me enough to use plastic on something thats pretty much mission critical. spend the 4 bucks and buy the worm clamps.
I was always told...do it right the first time or dont do it at all :)
