After years and years of building my own computers, I am getting ready to take the plunge into water cooling. I could use any feedback out there about gear and choices.
My current system:
I7 920 @ 3.6 GHz w/Corsair H50 cooler
OCZ 6 GB Ram w/fan cooler
XFX 5870 stock cooler
ASUS P6T Deluxe V2 motherboard
Silverstone TJ09 case
I would like to build water cooling for the CPU and GPU and was thinking of the following items:
Black Ice GT Stealth 240 for underneath case top since height can be an issue
Swiftech MCR120 QP - for side inlet
DD Summit Block for 5870
Swiftech MCP655-B
EK-Multioption RES 100 Rev 2
Swiftech Apogee XT
Tygon 7/16in. ID 5/8in. OD tubing
DD High 1/4" Flow Barbs
Feser One Cooling Fluid
3 Scythe Gentle Typhoon 120mm fans running at 1850 rpm
Loop would be: res -> pump -> 240 rad -> cpu -> 120 rad -> gpu -> res
I am hoping to hit 4 GHz on the cpu and leave the gpu at factory settings. I am assuming that a 240 rad for the cpu and a 120 for the gpu would be adequate cooling
for this setup.
Any feedback or comments would be appreciated.
My current system:
Swiftech MCP655-B
Swiftech Apogee XT
for this setup.
