Ok so I'm in the design stages for a case I want to build. It's a media server and right now it has 3 capture cards and will probably have a forth by the time I'm ready to build the case. Right now it's obnoxiously loud so I want to go to water cooling. The question I have is regarding the capture cards. Two of them have mpeg encoders with cooling fans and I'd like to wc those as well. However I want to use 1/2 inch tubing for the system. So is there some way I can take the 1/2 tubing and make or buy a junction box that will split a single half inch tube into four 1/4 inch tubes. Then I could buy those cheap GPU blocks for the evercool system and use them to cool my video card, 2 capture cards and maybe even the northbridge. Does that make any sense? Or should I try to squeeze the 1/2 inch tubing in? Thanks for the help.
