WC inside a Silverstone Tj03
HRPC
I want an internal solution (no rad box hanging off the back) has anyone done this in a Tj03. Seems like there is a lot of room, I was thinking of using the front 120mm intake fan and placing a single height rad there.
Any tips. I browsed the pics section but did not notice this setup.
Thanks.
Thanks. The only problem is that it is really loud and I want to use WC to quiet the system down! I will take a look at that dual 80mm rad
there isnt enough room in the front 120mm intake for a 120mm radiator. ill soon post pictures of my SCWCDM Version 2, this time in a TJ03!
