WC Help needed for a newb
tOb3o
right, my rig as it stands:
amd 4200
foxconn c51xema22
2x XFX nvidia 7600 gt xxx
2 gig of gold ocz shiz
blah blah blah
all in an antec p180 case
now i want to move into water cooling, purely as a project. i want this all to be internal and i realise that there maybe considerable amounts of case modding involved inorder to get things how i want. with the little knowledge i know and a days worth of forum reading and googling i've decided upon this system:
Swiftech Apogee GT Waterblock
Swiftech MCP655 12 VDC Pump
Thermochill PA160 Radiator
with a t-line (i want to make this visible from the top so boring and drilling holes, lil help with what to use on this please)
Vantec stealth 120mm fans
And im unsure about what pvc tubing to use.
i would like to know what is the best north bridge block to use. as far as connecting goes i've gathered its best to go pump -> cpu -> north bridge -> t-line -> pump please correct me if im wrong.
Please could someone just breifly read this and check that what i've got will work together. This is a project i will hopefully be entering within the month. I will post whatever i can to show you guys. Errrrm anything you guys can think of to help me out will be awesome any tips and things. Thank you
edit:-
i've also heard that anti freeze and water (25% to 75% water) works just as good as any solution for water cooling?
I've thought about it and i might scrap the northbridge route and try for a graphics...but there are two cards....any help?
