WC-friendly cases like TJ07?
kipling100
Are there other cases like the TJ07 where you can put a triple or quad radiator in a lower chamber that is isolated from the motherboard? Has anyone done this with the Corsair 800D?
I like internal WC setups, but I dislike the trade-off of heightened ambient temps when radiators are used as intakes to get cool air or vice versa.
Thanks for any help!
I think some people mount rads in the top of the 800d.. but I dont think theres room for one on the bottom.
I've seen some on the bottom with a triple, but you do have to cut out the drive bays that are down there. Not sure about a quad, don't think it is going to fit with the power supply.
With the Corsair 800D that is.
Maybe a slightly smaller version of this case would meet your needs? :D
That case could hold 2 quad and 2 triple radiators. :cool: :D
