I just finish rebuilding my loop, I decided to move from a swiftech MCR320 and a apogee XT rev2 to Black Ice SR1 360 and Raystorm block + some other goodies...
My main goal is a powerful quiet computer and in my old setup I had dual MPC35X pumps running @ 3300 rpm for 0.9 GPM but always found them just a little to loud so i made a few changes to my setup and heres how it turned out.
The Heart of the new system... MPC35X2 + MCP35X
It turned out much better than I had expected, everything really matches color wise and other than a couple of wires i need to sleeve i am pretty happy with the outcome.
The over kill of 3 MCP35X really shows its power when i can run all 3 @ 1200 rpm and get 0.5 GPM or 2000 RPM for 1.0 GPM. If i set them to 100% (4400RPM) I jump to an insane 2.3 GPM.
My old setup with 2 pumps maxed out at 1.4 GPM so the extra pump and less restrictive CPU block helped out alot.
So what do you guys think?
