WC Box Design *56K Beware*
amoeba1126
I'm trying to design an external housing for the WC of my HTPC. If you can give me any suggestions, it would be greatly apprecated.
D. Purple - 5.25" Fan Controller (Sunbeam most likely)
Green - 120mm Panaflo L1A Intake Fan
Red - Black Ice GTS 240 w/ 3x Panaflo L1A
Blue - Swiftech Microreservoir
L. Purple - Silver DD Fillport
Orange - Swiftech MCP655
Black - PSU
Tan - Interconnect Barbs
Grey - Mesh for better air flow
An issue I am having is how do start the PSU without using a mobo and just a power button. Ideally, I want the kit to "boot up" when the HTPC boots up, so if there was some sort of relay kit, that would be great. If not, I am content with just having an individual power button.
Also, should I include handles on it and make it a portable WC kit in case I want to use it on more than just one PC or would that make it look tacky?
connect pin 13 on your computer's PSU's 24-pin connector to pin 13 on your waterbox's PSU's mobo connector, and do likewise for pin 14.
And I'd suggest Swiftech's MCR series if you're going for low noise, which I'm assuming from this proposed setup being used for an HTPC.
will do and im thinking about just throwing away the psu idea and getting a multiport and 12v extention.
I revamped the design to improve airflow.
https://webspace.utexas.edu/chenjy9/Computer/WC Box 2.jpg?uniq=jrn90y
D. Purple - 5.25" Fan Controller http://www.frozencpu.com/products/985/bus-11/FrozenCPU_Dual_Voltage_6_Port_Baybus_w_BlueRed_LED.html?tl=g36c17s285
Green - 120mm SilenX 14dba http://www.frozencpu.com/products/4...-_72CFM_iXtrema_Pro_Fan_IXP-74-14.html?tl=g36
Red - Swiftech MCR320-QP 240 w/ 3x Yate Loons http://www.jab-tech.com/Swiftech-MCR...r-pr-3320.html
Blue - Swiftech Microreservoir http://www.jab-tech.com/Swiftech-MCR...o-pr-3093.html
Aqua - Silver DD Fillport http://www.jab-tech.com/Dangerden-Fi...r-pr-3052.html
Orange - Swiftech MCP655 http://www.jab-tech.com/Swiftech-MCP...p-pr-2982.html
Violet - Multiport for 12V http://www.frozencpu.com/products/5514/bus-98/Thermaltake_Power_Station_Mini_Box_A2359.html?tl=g 36c17s424
Grey - Modder's Mesh for better air flow http://www.mnpctech.com/moddersmesh.html
Brown - Aluminum divider for better airflow
Black - Hole to draw in 12v cables
__________________
