I've run into an issue, in my 7x GPU rig (yes, for mining), where the 7th card connected to my motherboard (Z87-G45) cannot be used due to "code 12: not enough free resources." If I can somehow run this GPU off of USB or another non-PCI-e interface, this should solve this problem.
I use USB to PCI-e risers, like this: https://bitcointalk.org/index.php?topic=392536
It connects to the GPU via PCI-e, but theoretically I could plug the other end directly into a USB port, while giving the card power as usual via SATA. Could this work, and would the PC recognize it? Thought I'd ask before I tried and fried something.
Thanks
Thanks
