Way to conrol CPU fan via software
The hardware fan controller that is on my motherboard does nto seem to work properly, it cannot keep the CPU fan running at a constant speed (it will spin up and down while the computer is idle). What is a good way to controll it with software? I am using SpeedFan right now, but it seems to not controll the fans sometimes, even though it reports that it is. Any reccomendations?
EDIT: Also, the machine tends to "howl" when the fan is at certain speeds. The case is thick steel, but it does have a window. Is there any way to prevent this? Would acucoustic foam help?
On my board I ran into a conflict with Speedfan and Smartguardian(software that ships with dfi motherboards). My main system is down atm, so I can't tell you exactly where to look. Its the last tab when you configure everything. I had to select from the dropdown box the chips that controls the mb fans and change it to software controlled and check the box that said remember this setting. And if I ever launched Smartguardian it would change everything again. Also make sure nothing in the Bios is set to adjust any of the fan speeds.
Also some motherboards only allow monitoring of certain fans and not full control.
