Way past time to upgrade
Nalif
I've been out of the PC world for a few years now, and haven't bothered keeping with the trends or anything. Currently I'm running a shuttle PC with a 2.4c P4 and a 9700 Pro, so I've been out of it for a while :D
I recently picked up a few new games (DragonShard, HL2, WoW, BF2, etc.) And lets just say my computer is feeling it's age. So I'm looking to upgrade - all new parts. I'm going to turn my current shuttle into a home theater setup, so just getting a few new parts is out of the question. I figure I'll pick up a Lian Li case - The PC60 is looking pretty good to me right now, but as for actual hardware I'm clueless. Here are the guidelines I have in mind.
I want this to be my first watercooled setup, but I want to keep it under 1000.00 USD. I already have the monitor and sound taken care of - I picked up a 2005FPW, a set of Logitech Z550's and an Audigy 2. That being said, I'd like a recomendation on a mobo/proc/video card setup, and some links to some basic watercooling kits with newbies in mind. Like I said - this is my first setup. I want a kit that looks professional and clean, something that will go with a Lian Li nicely. I'd like a modular power supply, but I need a recomendation on which to go with - I've always used stock power supplies, so I have no experience here. I also want this to be a PCI express setup. SLI isn't a must, but if it fits in the budget and seems like a good idea, I've got nothing against it, although it seems like it would be a hastle with water cooling.
So to recap: I want to keep it under 1000 dollars. I want a Lian Li case, a watercooling kit fit for a n00b, and a mobo/proc/video card/RAM combo that'll overclock well enough to make that watercooling kit worth the investment with SATA HDs and a modular PSU. So what should I go with? Intel? AMD? What's trendy at the moment?
Axman said:
AMD is better in all ways right now. That's not bias, it just is.
I checked out that article, and while it seemed to support this, it didn't give much insight into it at all. I checked out the intel forum, and it seems people are getting some pretty intense overclocks over there - with some saying they're getting 4.0-4.5ghz without too much invested into cooling. So what makes AMD better right now?
Well...the AMD can Overclock too ;)
It boils down to efficiency and price to performance ratios. Besides being more capable at a lower frequency, AMD chips do cost less for similar performance Intel chips. The lower frequency (in GHz) among other design differences mean that AMD chips use less electricity and put out less heat, good for the bills and good for the overclock. Essentially, because they start cooler, a similar cooling set-up will affect AMD better. That's a bit simplistic; there are some heat barrier issues and other architectural differences in the way Intel manages it's memory that limit the upwards end of the overclocks, but nonetheless true.
In a cinch, here's what makes them better: for the same number of dollars, you'll get a remarkably better AMD chip, especially when it comes to playing games, than an Intel chip.
That and there's this incredible deal for AMD rigs:
http://www.newegg.com/Product/Product.asp?Item=N82E16813188002
You buy that board, which isn't bad at all, though not the greatest platform for overclocking but fine for air, and get one of the arguably best video cards available at a $130 discount for the pair. (That would be the card with the combo special beneath the motherboard.)
Pick out a CPU, maybe an aftermarket heatsink, a hard drive, maybe a combo card reader/ floppy drive, a dual-layer DVD burner, and anything else you don't already have, I'm sure for a grand you'll have a killer rig.
Wow, that does seem like a good deal. I was interested in this being my first attempt into the world of overclocking and watercooling, though, and from the sounds of it, that wouldn't be one of the boards that would be good for that. However, I may have to go with that board seeing as how that's such a great deal on the card with the combo. I guess I'm off to check out some reviews on that mobo and see how it fairs.
http://www.svc.com/watercoolingkits.html for more.
The FAQ isn't totally accurate* and watercooling equipment is expensive. Blocks are machined in small batches by machinists; these guys are expensive professionals. They are often lapped before you buy them and made of copper and gold. It really isn't something you do for less than $150; those Aquagate Mini systems are only marginally better than air, though the Aquagate isn't terrible, but I'd hesitate to put, say, the GPU in the circuit. I don't know, though, I've never bought one.
Though I am certainly not trying to discourage you; the opposite. I think it's definitely worth putting together a loop on your own; it's not going to be much harder than the kits are to assemble (especially when the kit is just all the components at a combo price) and you can hand-pick your parts that way.
Also, kick around in the For Sale/ For Trade forum for some used watercooling stuff. You might have to dissasemble and clean it all, but it's at least a start.
Otherwise, there are quite adequate air cooling systems that are not any louder and still very good with overclocking, for example, the Thermalright SI120, with one of these on it: http://www.jab-tech.com/YATE-LOON-120mm-Case-Fan-D12SL-12-pr-3009.html.
*I appreciate the efforts that went into it, however, as they have help me immensly.
Axman
Thanks for all the links. I was really just looking into getting into watercooling to learn something new, and because of how it looks and the fact that not many people do it. I could do air cooling no problem, but I'm more interested in watercooling. It looks like I'm going to just skip it, though, because there's a lack on info for new people it seems. The way it looks, you can piece together your loop or buy a really expensive kit, and I'm just not finding enough information to piece together my own.
Don't get a DFI LanParty unless you're really going to extremely overclock.
As far as the modular PSU goes, my OCZ ModStream has treated me well. Go for the 520W version if you get the DFI mobo, or else people at DFI-Street will gnaw your face off.
