I have a WaveMaster and the left side door (main door) seem to rattle/vibrate alot in response to constant HD use or DVD drive (NEC 3520A) use. I can push inward on the door and the sounds go away. Does anyone else have this problem with their WaveMaster?
How can I get rid of the sound? All screws are tight and the door is on correctly. Thanks.
