Erasmus354 said:On a budget you dont want stuff from sharka. They deal in mostly import stuff which while some people like how it looks, is not a good choice at all in the price/performance arena.
Pooky said:If you wanted a true low flow setup, an Eheim 1046 coupled with a filltank from either Innovatek (a Tank O Matic plugon) or Aqua Computer (the AquaInlet), plus a Noise isolator dual pass single 120mm radiator (it's around $35) and an Innovatek XX-Flow CPU block (http://www.sharkacomputers.com/inxxcpuwablw.html) or even a Flatflow can be had for pretty cheap. Throw in 10mm OD tubing and fittings and you're set.
When I went low flow around 2 years ago, that's what I started with. I added more later on when I wanted, but didn't break the bank to start. I also don't really care for the Aquatubes myself, and nothing beats a filltank anyway![]()
