Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
well, you've got a pump, a waterblock and a radiator. the waterblock tranfers heat from the cpu to the water, keeping the cpu cool. then the water goes through the radiator where it is cooled by fans blowing over the fins. then it goes back to the pump and starts all over again. that's the basics of it, i think i got it all in there. if not I'm sure someone else will correct me.
