DMystikaLD
- Apr 14, 2003
I am currently running a Zalman 7000cu on my P4 2.8 and am in a college dorm. Since it's pretty damn hot in there I'm looking to replace the Zalman with a liquid cooling system. The maximum I can spend is $350, and I'm looking to get the best bang for my buck and be able to overclock quite a bit more than I currentyl am ( I can run 3d mark all the way through just fine on 3.57 ghz , but the heat is crazy in my dorm room and unfortunately I cannot overclock past 3.2 without causing heat problems)
I don't want a pre-built kit because I KNOW that I can piece together a better system for probably a good amount less. I'm looking at either Danger Den or Swiftech for the blocks and I'd like to cool at a minimum the CPU and GPU. Is cooling the NB worth it?
What resevour should I get? I think those dual 5.25 drive bay ones are sweet ass, and I'm definately looking at getting some gook to color the water
Also, which is better, 1/2 tubing or 3/8 tubing?
I see two pumps available at FrozenCPU that push 180GPH. The swiftech and the Hydor. Which one, or is there one that's better?
Obviously I'll also need clamps, fittings, etc., so I'd like to know all those accessories that I'll need. Same with fans, water additives, etc.
Thanks guys!
Thanks guys!
