watercooling with koolance RM2-4U
hairy
Hey, I just got my koolance system hooked up. I live in a place with seldom-running air conditioning and even poorer ventilation, so I thought water cooling would be best. Right now I'm running a 2.5ghz northwood (not overclocked) and that with a CPU-305-V06 waterblock is the only thing on the cooling circuit right now, but all this stuff is the first step i'm taking toward a e6300 + p5w + x1950 pro system, and the first few weeks of watercooling have raised some questions:
1. My CPU temps are fine but now my motherboard temp probe (i guess it is somewhere on the south end) is reporting 50C internal temp while the CPU is at 40. My radiator has 3 fans running at medium and i have a 30-ish CFM 80mm for exhaust (just like how i had in the crap system before the case upgrade). When I stick my head in the case, the hottest area for sure is around the memory (i have a sapphire r9700 that hardly gets warm). What can I do about lowering the in-case air temps? Would a PCI-slot fan do anything? I had one lying around but I can't find it now, but if you think it'll make a difference I will buy another.
2. How many waterblocks can I add to this thing without hampering performance? It's just the regular koolance system with 2 redundant pumps and I will probably only use 1/4" koolance tubing and waterblocks, but if, in addition to solving question #1 above, I could expose my 2 hard drives (with the dual hydra-pak thing) and the future x1950 pro, I would be satisfied. I dont want to watercool the RAM modules or anything like that, but I know there isn't much air moving around in the case so a watercooled CPU, GPU, and HDD would make me feel alright, but the thing is that when I was filling up the system for the first time the flow rate of the system was not as much as I expected it to be. I was curious as to what other koolance set ups you all had and how many h2o-cooled devices are chained onto the system.
thanks
alex
