Watercooling. Which case?
nice - a NZXT rep on board! How soon do you think until Amazon (prime shipping) has some in stock?
Also a suggestion for the ODD stealth plate - Mske two sets of screw holes in a lower 5.25" drive bay so it can be relocated lower. You can't mount a thick (50mm+) radiator up top and have a ODD there as it is.
edit: also noticed I can get shipping to 96813 as low as $28 direct from nzxt. not bad. I'm glad you give more than one option for Hawaii.
also - how did I miss the thread you started almost 2 weeks ago?!
The stealth bay certainly proved to be more of a task than originally thought, the issue is that the stealth bay needs to be more recessed than the other drives to properly fit the cover on top of the bay, but that would mean if you wanted to use the 2nd bay for a fan control it too would be recessed.
