Watercooling - which case mod please?
b0redom
Hi,
I'm planning on this lot. Later on, I plan to add an Asetek Waterchill CPU cooling kit - KT12A-L20/220V 10mm to it. Which case should I be looking at?
I want this thing to be QUIET! :)
AMD Athlon 64 X2 Dual Core 4400+ (Socket 939) - Retail
Asus A8N-SLi Premium NF4 S939 DDR400 PCI-E SATA
Corsair 2GB DDR XMS3200C2PT TwinX (2x1GB)
XFX GeForce 7800GTX Extreme Edition 256MB GDDR3
Western Digital Raptor 74GB 10,000RPM SATA 8MB Cache
Western Digital Caviar Special Edition 250GB 2500KS SATA-II 16MB Cache
Pioneer DVR-109 16 x 16 DVD±RW Dual Layer ReWriter
600W Enermax Noisetaker SLi
Cheers...
Tom
Pick any full-sized or file server tower that you like and that is within your budget. From the gear your purchasing it looks like budget shouldn't be much of a concern... you can get "cheap" full sized cases on e-bay for $35-$50, really nice ones from $75-$150, gorgeous ones for a little above that, then you get into the realm of Lian-Li, Supermicro, Coolermaster, etc server towers up to about $275.
Decide if you want steel or aluminum (steel tends to have slightly better sound dampening qualities from my experience (but that's easy compensated for on an aluminum case with sound dampening foam), aluminum is supposedly a little cooler and much lighter.
Start with looking at:
Lian-Li PC75
Lian-Li v2000
Lian-Li v2100
Lian-Li 7077a
Coolermaster Stacker
Coolermaster Stacker 2 (coming soon)
Supermicro SC750a
Yeong Yang YY-0221 (not a fan of this case)
Enermax SOHO Case
Thermaltake Kandalf
Thermaltake Circle
Silverstone Temjin
Antec SOHO File Server Case
Blah, blah, blah... I'm a fan of Lian-Li cases myself but others will disagree... that's the beauty of modding... it's all about making it your own. Find a case you like with enough room, read a few reviews to be sure it's quality... then start hacking away.
