I dont wanna build one myself.
Rather just buy a watercool case with everything..
$ isnt an object.
What do you recommend?
what do you guys think about the THERMALTAKE KANDALF LCS LIQUID COOLED black
ill be running these specs
wd raptor hdisk -
intel core 2 dueo e6600
NVIDIA 8800 GTX -
corsair dominator - 2gb -
eVGA NVidia nforce 680i SLI OR ASUS P5k
Well basically for a newbie with lets say $300-400 to spend ..
As you see, my specs are pretty good. Im trying to build a super pc basically. My old pc i built 4yrs ago isnt cutting it anymore.
dont even know what a dremel is. Ive assembled air cooled cases never even messed with a water cooled one.
Maybe ill stick to air cooling for now.
whats the easiest way to get a watercooled system..
buy a case?
You don't have to do any cutting... a triple radiator can be mounted outside the back of the case.
