I'm thinking about doing another water cooled system. My last water cooled system was built probably 7 years ago, and alot has changed since then! The case i will be purchasing is a Corsair Obsidian 800D. If you have a minute, please let me know if i have a wrong part or mismatched items. Thanks for looking. I'm planning on cooling an Intel 775 quad core and a GTX470 in this loop.
Black Ice X-Flow Radiator - Will put in the top of case, should pretty much drop in correct?
http://www.frozencpu.com/products/5069/ex-rad-93/Black_Ice_GT_Stealth_360_X-Flow_Radiator_-_Black.html
XSPC Dual 5.25 Bay Res with Swiftech MCP655-B Pump - This pump will sit in the bay res (i believe)
http://www.frozencpu.com/products/11219/ex-res-232/XSPC_Dual_525_Bay_Reservoir_-_Laing_D5_MCP655_w_Blue_LED_Light_-_Clear_Silver_Black.html
Danger Den DD-GTX470 Full Card Cooling Block
http://www.frozencpu.com/products/11355/ex-blc-796/Danger_Den_DD-GTX470_VGA_Full_Card_Liquid_Cooling_Block_-_Satin_Copper_Base_Smoke_Acrylic_Top_GPU-6910-SA.html
Tygon 1/2" ID 5/8" OD Tubing - 6' should be enough
http://www.frozencpu.com/products/2289/ex-tub-28/Tygon_R-3603_12_ID_58_OD_-_Laboratory_Tubing.html
Radiator M4 x30mm Mount Hex Screws - 3 Packs of 4
http://www.frozencpu.com/products/11343/scr-167/M4_x_30mm_Radiator_Mount_Hex_Socket_Cap_Screws_-_Black_-_4_Pack_Danger_Den_Hardware_Labs.html
Apogee XT CPU Block & 775 Backplate
http://www.frozencpu.com/products/12683/ex-blc-883/Swiftech_Apogee_XT_Rev_2_High_Performance_CPU_Waterblock_-_Sockets_77511561366.html
Koolance 1/2: ID 5/8" OD Compression Fittings
http://www.frozencpu.com/products/5481/koo-72/Koolance_12_13mm_ID_G14_Threaded_Nozzles_Pair_NZL-V13P.html
Bitspower G1/4" 45 Degree Adapters - Couple these to avoid unnecessary bends.
http://www.frozencpu.com/products/7928/ex-tub-372/Bitspower_G14_Silver_Shining_Rotary_45_Degree_G14_Adapter_BP-45R.html
Is there anything i'm missing or am i choosing inferior parts?
Thanks for looking!
-bill
Thanks for looking!
-bill
