Hello everyone.
I'm just about to take my first steps into the world of water cooling and I thought I would ask you good ppl for some advice before I start buying the parts needed.
I have put together a list of the parts im buying.
Swiftech watercooling kit
http://coolpc.com/Swiftech-H20220-A...src=GB&utm_medium=organic&utm_source=GB&id=uk
ATI HD 4850 watercooling block X2
http://www.thecoolingshop.com/product_info.php?products_id=3282
Northbridge Water block
http://www.thecoolingshop.com/product_info.php/products_id/2415
all the items listed above will be fitting an i7 intel DFI motherboard (I dont have the link saved to this computer but will edit this post and include the motherboard model). It will also be placed into a Cosmos S PC case
http://www.chilledpc.com.au/images/Projects/cosmos s.jpg
What im worried about the most is ordering the parts and getting the incorrect fittings. I know that the Swiftech kit comes with size of 8ft 7/16" flexible PVC tubing. But will the tubing be correct for the rest of the kit, and will I need more then 8ft?
any help and advice would be greatly appriciated
