I have a XSPC EX 360 rad with XSPC Dual 5.25" Bay Reservoir - Laing D5 pump/rez combo. Will that pump be enough if i add a XSPC RX 240 rad to the loop?
I would sure think so. The D5 has decent enough pressure/flow rate to push through quite a bit. But how many water blocks are in this loop? A CPU and 2 GPUs I would assume, based on your sig rig. I'd still think that was enough, but you'll see others here with two D5 pumps, which maybe be excessive in your case. But this is the place for excessive. Try it and see. Upgrade if necessary. Also, browse the WC gallery and see who has something similar and see what their config. But my gut and limited experience with the D5 in my previous WCing loop say that is it enough.
That will definately be enough from all of my reading you would more need to b worried about your pump if you had the x20 750 but you will b find for many mods to come
