I am starting a watercooled Micro ATX case. It is my first water cooled PC, and im going to be making a worklog.
I'd appreciate any support for my project, and I'll get ahold of a new digicam before I start slicing and dicing. I'll get back to putting together a parts list and a worklog in a few days, but I have a quick question.
When I get all the parts for my watercooling system, is it a good idea to place my boards in the box and measure all the tubing, cut, assemble, and test? Once the test is over (if succesful with no leaks or air catches) I would leave my system aside pre-assembled and ready to bolt on.
The exact question is once tested and filled should I purge and reassemble the system or bolt on with fluids in?
Good or bad plan? ( I don't like the idea of filling the setup while its mounted on hardware, but I would do it if its not feasible otherwise)
Also, PC ice Yay or Nay?
