I am planning to upgrade to conroe pretty soon and I want to do some serious overclocking so I have been trying to make sure my water cooling system is in good order. I have an Athlon XP 3000 running at stock speed with a 120MM radiator with a 57cfm rated fan and 3/8 tubing and a Danger Den Maze 4 block and CSP Mag pump. My computer shut down from overheating one night after not having happened for a long time and I looked at my radiator fan and it was going slow so I replaced it with a better one. Before I did that after cleanign soem dust out and what not I was getting readings of 46-48 celsius temps at idle and 54-56 temps doing super pi. Now I got a new case and running 2 120mm fans on the radiator and 1 120mm fan on my hard drives and flushed out and replaced my fluid and I am getting 44celsius temps at idle and 50-54celsius at load.
This seems fairly hot to me, ambient is around 75. Also the voltage is reading 1.73 or 1.78 dont remember which seems high too. I don't remember what temps I was getting when I first went water cooling so I don't have anything to compare to. Do you guys think the readings could be off, for some reason my voltage is high, or the maze 4 block just isn't that great and it will be better with a swiftech apogee?
