watercooling issue, need suggestions
lostpnoiboi
Im not sure if this is algae but thier are foamy like stucture that has built up on my resevoir. If this is algae what can i possibly do to remove them without cleaning them physically.
I am using a Fluid XP water coolant. Do you guys think because this product is base on "food particles" that this foamy like algae structure could be it?
My first suggestion is to post watercooling-related threads in the watercooling subforum. Second, "food particles"?
you sure its not just air bubbles? Nasties shouldn't be able to grow in FluidXP unless you did something stupid like mix it with water thus diluting its properties (and negating any non-conuctiveness it ever had)
that could of been the problem. I used a tube which i washed with h2o, but i also waited for it to completely dry. Im pretty sure its not bubbles. if i can get a hold of a digi cam i'll try taking pics.
I have done some searching and found an anti algae treatment called asetek waterchill with waterwetter. Anyone know if this can be mixed with fluid xp or is it just primary for waterchill products?
