nimbyfaygo
- Jan 18, 2006
I admit I was a skeptic regarding watercooling. I took the plunge and purchased a used setup from a forum member here.
My main reason for buying it was for the case mod I'm working on. I finally got it installed and running on my current system.
I tested the setup, and last night I clocked my Q6600 to 433 x 9 = 3897mhz. I'm at 1.58v under load.
As hard as I tried, I never could get 4ghz. I didn't want to crank the voltage above 1.6, and I have cheap ass ddr2-800 ram.
The temps are showing 55-57c. Its been stable for 12 hours running folding@home, 100% loaded all cores.
For comparison, the CPU was running just under 70c using the Cooler master Hyper 212+. With the CPU clocked at 3.3
I initially had it at stock clocks, the temps were at like 28c!
I don't have any pics of the parts installed, because its all just sitting in a pile next to my case.
The parts consist of
danger den CXP
GT Stealth 240
Swiftech Apogee GTX with copper top
danger den CXP
GT Stealth 240
