Watercooling inside a fragbox
bsmack
For those who don't know what one is, look here:
http://www.falcon-nw.com/fragbox.asp
With that being said, my FX-53 is overheating in this thing, and I have minimal space to work with. Would there be a watercooling solution that would work and preferably fit inside the fragbox?
I think I'm gonna get the coolermaster aquagate mini r80...that seems to be the best I can get, and the reviews aren't that bad. I know it's not the best, but I'm really not looking to OC, and am just looking for my machine to be stable under load since my zalman HSF isn't cutting it. Are there any others I should be looking at, or is this my best choice?
What heatsink are you using now? And how little space are you talking about? Have you checked whether one of the thermalright beasts would fit in there?
