watercooling in a stacker
jetjaguar
im thinking bout going cheap and not getting a tj07 or another lian li ..
selling my stacker 810 and getting the original stacker ..
here are my questions .. does the ocz 520w psu fit up top .. i remember reading people had problems fitting certain psus up top ?
i have 3 hds and might add another one down the road so i need to use one of those
3into 4 modules .. i need to run a double rad up front .. so that will only allow me to run 1 hd case and 1 optical .. no room for a fan controller .. or am i missing something ?
also does the thermochill 120.2 fit in the front ? i know the bix II does but i wanna use quiet fans .. ?
the performance wont equal the bix II right ?
will the bi II pro be enough to cool sli'd 512mb gtxs and a cpu
Yes, it does.
A PA 120.3 will fit also but leaves room for only one optical.
Another Option: Buy the BIX II shroud to mount the rad on the bottom of the case in the mesh opening.
My OCZ Modstream 520 fits Like a Glove, but I do remember having to fight with the case just a bit.
My PowerStream 520 fit just fine. Had to be careful not to scratch the pretty nickel sliding it in, but other than that fits like a glove!
jetjaguar said:
i have 3 hds and might add another one down the road so i need to use one of those 3into 4 modules .. i need to run a double rad up front .. so that will only allow me to run 1 hd case and 1 optical .. no room for a fan controller .. or am i missing something ?
There's 11 usuable bays, 12 if you relocate the power switch. There's also a 3-in-2 module available to save another bay.
