Pkirk618
- Sep 12, 2002
I have the system is the sig and I used to love using my nautilus 500 for overclocking whenever I had the urge to experiment with my cpu's limits. With my i7 setup, the only reason I'm not OCing beyond are the temperatures.
Does anyone know if there is a bracket, clamp, adapter for my old WC setup or what should I consider using as a replacement block. The block it comes with is amazingly well put together and that's why I wanted to keep it but if I have to, I'll change it. Suggestion? I'm looking to check out fry's tomorrow if you know something is there for pick up. Otherwise, there's no price limit--I just want a quality block.
I'm currently using a v8.
