Watercooling fitting problems.
anths
Hey guys, I am using a Hydor L30 pump which uses a 3/8'' ID outlets but everything else in my system is 1/2'' ID. For the pump should i just put my 1/2'' tubing on it and clamp it tight or is there some sort of adaptor i can buy?
BTW: I am buying everything from www.frozencpu.com
just put a clamp around it.. it'd probably be a good idea to clamp all your hoses anyway...
