-=iNsAnE=-
- Dec 16, 2002
i'm fairly new to watercooling and i just recently put together a setup with all swiftech blocks the specs are as follows..
swiftech MCW5002 cpu block
swiftech MCW50 videocard block
swiftech MCW20 chipset block
hydor L30
procore with 120mm evercool fan
my layout goes pump > heatercore > cpu > videocard > chipset > res > pump and i have no other fans in my case except on my heatercore and in my psu.. no exhaust fans
my temps at 1.95v run around 43-46C (via temp probe) full load.. which i think is kinda high
so here's my questions..
1.) should i get a differnet cpu block? i was looking at the whitewater and if i threw it in my setup as it is now.. how would it peform compared to waht i already have?
2.) should i change my layout of my tubing so it splits and goes into my cpu and videocard then back into my chipset (considering i have the WW) or would that just hurt flowrate and reduce temps even more? but i do wanna get the highest videocard OC possible as well
3.) should i do either of the 2 above but totally ditch the chipset block?
4.) should i have any exhaust fans? since my case temp runs around 33-35C (via temp probe)
i know my temps are considered safe.. but i can push this thing farther but when i get around or over 2v my temps get even hotter.. i appreciate anyone who took the time to read all this and i hope one of ya has some suggestions for me.. thanks!
hydor L30
