I have about 150-200 to spend and I decided that my air cooling just isn't doing enough. My room is usually quite warm thus I have to keep the side of my PC off so my case temps dont go above 50C. If I put the panel on, my case temp goes to 51C which is too warm for my taste. So I would like to get water cooling just so I can keep it cool and quiet. A small overclock is fine but not too much because I dont have good OCing RAM. Specs are in sig. Thanks.
