Hi,
I've managed to get this setup from a friend of mine. However, I'm not sure if I really want to go with this. Anyways, here's the setup.
Koolance Exos II
Swiftech MP350------------------------->With the acrylic top mod.
GPU Waterblock for 8800 GTS----> I think it's a full block, covers the whole GPU.
Swiftech Storm Rev I
This setup would be cooling my q6600 and 8800gts 640.
Anyways, I'm thinking of ditching the the koolance part of the setup and buy 2 MCR120 radiators and have them placed in two different spots. Would this work ok? Also, there's 2 version of it, one with a built in reservoir and the other without. Should I get one with reservoir and another without or get both without it and get a separate reservoir or T-line?
I'm thinking of either having them in series or have one in between the GPU & CPU.
Would the idea above be better than the setup with the koolance radiator?
Also, there's some discoloration of the blocks(ie. not shiny copper), would this be due to corrosion? If so, what's a good way to get rid of it?
Thanks for any suggestions.
Koolance Exos II
