Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
i jump started power supply to leak test. However, it works so slow. Water is not going thru the whole system yet. Is it bleeding or i did something wrong?
could just be air stuck some where.. thats my uneducated guess, since ive only setup one WC system and didnt really get to play with it that much since my PSU on that system went kaput..
hooray! you gotta show me this thing once its all hooked up turk. those pontiac heater cores are huge! i had to keep adding water to mine for a long time too before i finally stopped getting bubbles. had to pick it up and turn it over every which way.
