I have been having trouble keeping the Q6600 cool in my Antec Fusion @ 3ghz. Its ok in the winter but when its warm it can reach 80C-90C in Prime95, although its completely stable. I was thinking of watercooling it but thought the Antec Fusion wasn't suitable but I've had an idea!
Would it be possible to mount a radiator above the PSU in this case? I know mixing water and power probably isnt a good idea but then again water and CPU's in general doesnt seem that sensible so why not?
Any thoughts?
I was thinking of these parts...
Swiftech MCR120-QP-B 120mm Radiator http://www.overclockers.co.uk/showproduct.php?prodid=WC-006-SW
This could be mounted above the PSU with maybe another fan above it...
XSPC 200 Bay Reservoir & Pump http://www.overclockers.co.uk/showproduct.php?prodid=WC-007-XS
The reservoir could be mounted in the drive bay behind the VFD.
Heres a pic of the fusion to give you an idea...
My PSU (which is mounted in the top left) has a 120mm fan on top which is open and could pull air through the rad.
I'm new to water cooling so any help is appreciated.
Thanks!
Any thoughts?
Thanks!
