watercooling an X-QPACK
veeoo
How many of you have done watercooling with the X-QPACK case? Do you also have a waterblock for your GPU? I have a 6800GT and I'm wondering if there is room between the PSU and the top of the video card for a Danger Den 6800 block. Or possibly room to route tubing with a DD Maze 4 block? Also, are there any good nforce 4 ultra micro atx mb's out now?
Thanks for the help.
What blocks did you use? What size tubing? What radiator? What pump? Give me something....
I've been too lazy to get pics up :p
Anyway, I used the swiftech block (the new one) and then went with a Polarflo GPU because it can be turned. I also went with the new swify 120mm rad. A floppy reservoir (although the new swiftech one is what I would like to go with). Standard 3/8id tubing purchased at Home Depot. pump mcw350...it all fits nicely with only a few mods.
