Watercooling Advice
Brianmz
I'm planning to watercool a new build I'm going to make in the next few weeks in my current case which is a Cosmos II(not the best for liquid cooling, but the best available to me atm).
So far I have these parts:
Exhaust:
http://www.frozencpu.com/products/1...20mm_Radiator_-_80mm_Thick.html?tl=g30c95s667
Bottom:
http://www.frozencpu.com/products/1...20mm_Radiator_-_80mm_Thick.html?tl=g30c95s667 x2
Top:
http://www.frozencpu.com/products/1...ple_120mm_Low_Profile_Split_Fin_Radiator.html
Cpu block:
http://www.frozencpu.com/products/1...on_Intel_Sockets_LGA_1155_1156_1366_2011.html
Pumps:
http://www.frozencpu.com/products/1..._D5_Top_-_Laing_D5_MCP655_-_Black_Acetal.html x2
Reservoir:
http://www.frozencpu.com/products/1..._Ice_Red_BP-WTZM250P-IRDBK.html?tl=g30c97s165
I was wondering if it's a good set up, it will be used to cool a 3930k, Rive, and 2 geforce titans.
Currently own a 1200 watts PSU, which i hope should be enough.
Also need help on which fittings,tubing and other misc parts to use, since I have no idea which ones to use, only picked the rads, reservoir, pumps and cpu block.
Any input would be great!
