watercooling a shuttle
Absentee
well i have a SS51G shuttle with a s478 northwood that i would love to watercool
this shuttle will be going in my room as an HTPC and i need it to be silent so i can sleep
so heres my question
what parts should i use to fit inside a shuttle?
im using 3/8" ID (1/2" OD) tubing for this
i need:
a s478 CPU WB
a GPU WB that will fit a 9600 pro
a SMALL pump (i want this mounted internally, most likely under the HDD with the second HDD mount cut off) (pretty shure im gonna go with the swiftech mcp350)
One pump I can recommend for you is the DDC-12V from Danger Den and Swiftech. My oh my, it is a tiny pump. I can fit it in one of my hard drive racks with room to spare.
