Watercooling a GTX 670?
Circumnavigate
Does anyone know of an easy and inexpensive kit I could use to water cool my EVGA GTX 670? I wanted to use a Corsair H50 for my CPU and it would be nice to match it with something for my GPU.
You could get another similar unit to the Corsair H50 and buy the NXZT Kraken G10 bracket to install the asetek style block/pump combos to your GTX670.
Is you GTX670 a reference style card with the short pcb?
http://hardforum.com/showpost.php?p=1040649126&postcount=122
If so it would look kind of funny with a G10 like the post above as the fan mount that is supposed to cool the VRM section will be pretty useless. :p
There are also a few other brackets around that will do the same job, and quite a few people have just been mounting these coolers to their cards with zipties.
