CaribouNuggets
- Dec 7, 2013
Hello all,
I've searched this forum many times for ideas to build my new SG05. I spent about a month selecting parts and looking at other builds. I had one objective:
1) Switch from Corsair 650D to SG05 without skimping on features.
This required my build to contain the following:
1) Quad core
2) Closed loop watercooling for CPU
3) Decent graphics
4) Boot SSD
5) 1TB mass storage
6) Modular PSU
7) Optical drive
Here is the part list:
SIlverstone SG05
Silverstone 450W Modular PSU (ST45SF-G)
Asus Z87i-Deluxe
Intel i5 4670k
16GB Kingston 1600 RAM
Seagate 240GB SSD
HGST 1TB Mass Storage
Corsair H55
Asus GTX670 Mini
Generic slim Blu-Ray/DVD drive
SO here are the pictures:
Moving from Corsair 650D to SG05.
Side by side comparison.
I was tired of moving this case around the country.
Getting all parts ready. Switched some over from my old case. Waiting for new parts to come in!
Close-up of the Asus Z87i-Deluxe.
First test of the motherboard:
First case installation.
Everything assembled with old parts and new processor/motherboard.
This was just a test. There is much more to do!
NOW, moving to some upgrade parts after they arrived in the mail:
Some creative modifications were made. I ended up grabbing some elastic from Michael's while my wife was doing something. I cut it and stapled it in the middle to create elastic bands. The drive is secured to the side of the PSU with removable 3M sticky stuff. The elastic prevents it from falling after it heats up.
In order to get the drive to clear the radiator from the Corsair H55, I had to shave off some parts of the optical drive cage.
All done! It lays flat now.
Time to secure the 1TB mass storage. I didn't want a 3.5" drive crammed in there or have an external drive, so I went for a $70 HGST 1TB 7.2k RPM 32mb cache drive off Amazon. This required mounting to the bottom.
Velcro is on the bottom.
First thing to go inside the case. The radiator makes it difficult to plug in SATA power and SATA data cables.
First installation of the radiator. It has a Corsair SP120 PWM fan attached now.
Installing the Asus Z87i-deluxe. I removed the EMI foamy shielding on the I/O shield because it bowed out like crazy. I used Arctic MX-4 as the TIM. At load, it reaches 55degC. Not bad for SFF. Overclocked to 4.2Ghz.
Close-up of everything. I think the black/yellow looks pretty good. The HyperX RAM looks better in person, and that motherboard is really great. It's also very heavy...
Attached the front panel to the case and did a little cable management.
Inserting the modular PSU. The SSD attached is looking great.
Side-view of the case.
All power cables are attached. I had to re-crimp a few SATA cables to get it exactly how I wanted. I ordered the Silverstone short cable kit so I didn't have to worry about cutting up the cables that came with the PSU.
Another side-view of the case.
Dropping in the Asus GTX670 mini.
In order to get the power cable to clear the optical drive cage, I decided to cut off the unnecessary plastic and put silicone RTV into it to keep it flexible and rigid.
See? Not much space. I read before buying the card ($210 used on eBay!) that the power connector is really high. The PCB rises above the back bracket, and the 8-pin power connector is on the top and can butt up against the cage.
Yep. It comes right up through the cage.
Everything's installed!
Another side-view.
Ahhh... all finished. Kona Pipeline was the beer of choice (PCB-recycled coaster. Electrical engineer over here).
Complete setup. Everything's at home.
1) Quad core
3) Decent graphics
4) Boot SSD
5) 1TB mass storage
6) Modular PSU
7) Optical drive
SIlverstone SG05
Asus Z87i-Deluxe
Intel i5 4670k
Seagate 240GB SSD
Corsair H55
Asus GTX670 Mini
Another side-view.
