- Jan 11, 2009
I've just ordered some parts for this build, but basically what it will entail is this:
E8200 - Under water - Reusing
Dual 4850's - Bought
DFI LanParty JR P45 - Buying
4 GB RAM - Reusing
900w FSP Group PSU - Reusing
CoolerMaster Elite 341 case - Bought
That's about it for now. It's going to be a tight fit, but hopefully it'll work out. Anyone have recommendations for water cooling stuff for the processor? I'm new to water cooling, and this will be my first build with it. The case is here,
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119193&Tpk=elite 341
and what I plan on doing is mounting a 120.1 radiator in the space right after the intake fan hole. I'll mount a fan on the intake, and the rad behind it. Should be a snug fit. The pump will go wherever as of now, and the reservoir will be put in one of the remaining drive bays.
Thanks in advance
4 GB RAM - Reusing
Thanks in advance
