Watercooled 4850's!!!
R1ckCa1n
Well I broke down and got two Dtek FuZion GPU blocks to see what kind of temps they would net. I am undecided on what to do with the RAM since I couldn't get any of those nice Swiftech RAM sinks. According to my IR temp unit, the RAM is only running 41c anyways and the mosfets are 46c.
THE GOODS
NEW GPU BLOCKS!
PURE SEXY
IDLE
LOAD
So I guess these are not that hot of chips, just stock cooling isn't the best ;)
Nicely done! What's GPU temp #2? You only have 2 GPU cores yet they are showing 3? :confused:
I always believed that Water cooled GPUs should be volt modded :D. Go mod it!
You know the sad part is I watercool for silence...... You wouldn't believe how silent my rig got with no GPU fans blazing :)
I will mess with overclock later but just am enjoying the silence.
