TeleFragger
- Nov 10, 2005
Ok so I bought a XFX geforce 7950 GT and had it running...
it heated up my case temp a good bit so I threw on a vga water cooling block... and got it all together...now the card does not work... took the watercoooling off and put the regular fan back on and card still does not work.
can these cards be watercooled?
if so what needs to be done?
I blead the system before even powering it up so it had water before powering on.....
any ideas?
I get the same beep as if there is no video card in at all..
I came to that by removing the card.... powering on and it beeped a sequence...
then I put the card in and get the same thing.. yes I plugged in the power to it or it beeps a high pitch.....
any ideas?
