It's the block that performs the best. Right now the XSPC Raystorm looks to be the best bang for buck you can get. Very good performance (top 5 blocks I believe) while having the lowest restriction out of any of them. The top 10 blocks all generally perform within 1-2 C of each other, and that gap gets smaller the higher-end you go.
Just to note, the raystorm will not work with the rampage iv motherboard due to backplate conflicts. Still have yet to hear back from xspc regarding this.
I thought the Rampage IV Extreme motherboard had a second 1366 style backplate. If so, it should work just fine with the 1366 backplate, since the Raystorm is designed for 1366, and the 2011 holes are the same as 1366. 2011 introduces a new backplate style, which probably is incompatible with most 1366 mounts (I think).
Sorry in advance for the crappy photos:
Photo showing the supplied raystorm backplate:
Photo showing the length of the small backplate for the rampage, w/ an ek backplate over it:
Photo showing the large rampage backplate, notice the cooling holes.
Photo showing the raystorm backplate over the large rampage backplate(it has 2 backplates, one large that uses the mounting holes, and one smaller that does not).
to note: the raystorm backplate fits perfectly over my old 1366 board, but is too small to fit on the 2011 socket used with the rampage for some reason. hope these help with what i am trying to describe.
Many thanks. I hope XSPC offers a fix. I really want this waterblock for my 3930K. hrrmm I wonder if a chopsaw and drill press might work on it a bit hahah
Based on what I saw in the Rampage IV Extreme preview, they included a tool to remove the 2011 backplate and install a 1366 backplate, which should have been included with the board.
XSPC did indicate on their site that the Raystorm and Rasa should be already compatible with 2011.
Okay so is a backplate necessary? What about commando mounting?
